Screwed-- not what you think
RustyFarmall
09-29-2005 13:56:44
third party image
Sometimes farmers can make some pretty ingenious repairs, sometimes not. Started to work on an M carburetor, and found a large wood screw holding the choke plate to the shaft. The picture is not real clear, but I think you can see the screw.
PAULIH300
09-30-2005 13:04:49
 Re: Screwed-- not what you think in reply to RustyFarmall, 09-29-2005 13:56:44
That could have been the early,low budget forerunner of the "Tornado" mileage/HP device! lol
Those screw spirals create a swirling "Vortex" that aids in atomizing the fuel mix...
Yea right!
Ron in Nebr
09-29-2005 19:06:31
The idea behind that is that it works just like a barbed-wire fence, except instead of for cows it's purpose is to keep mice from getting in the carb when the tractor's in storage. Must work- ya didn't find any mice in there, did ya?
f-Dean
09-29-2005 18:59:53
I don't blame the previous owner. That screw is less likely to come out. We put a brass screen above the carb to keep the loose screwws from going into the cyclinders. Twice, once with a picker on, we had to pull the head to remove a carb screw that had make its way into the cyclinder and became inbeded in the top of the piston.
IH2444
09-29-2005 17:46:40
That is just a tuned venturi turbulence device. Gets better mileage.
Farmall Frank
09-29-2005 15:22:59
Are you suggesting it should have been a brass lag bolt?
Illinois Boy
09-29-2005 14:09:23
Rusty - you should patent that idea before some JD or AC guy sees this post and beats you to the punch!!
RustyFarmall
09-29-2005 14:12:34
 Re: Screwed-- not what you think in reply to Illinois Boy, 09-29-2005 14:09:23
Hey now there's an idea, just possibly could be my claim to fortune.
Illinois Boy
09-29-2005 14:18:12
 Re: Screwed-- not what you think in reply to RustyFarmall, 09-29-2005 14:12:34
Yeah - You could call it the "Complete" Carb Rebuild Kit company!! (Sorry - couldn't resist!!!)
RustyFarmall
09-29-2005 14:31:57
 Re: Screwed-- not what you think in reply to Illinois Boy, 09-29-2005 14:18:12
Good idea, wouldn't even need anything else in the kit.
Illinois Boy
09-29-2005 14:37:11
 Re: Screwed-- not what you think in reply to RustyFarmall, 09-29-2005 14:31:57
LOL!!!!!
