super oil pressure
wanabefarmer
09-30-2005 08:31:09
Just completed overhaul of "113" engine oil presure with starter turning engine with 12 volt battery,no plugs I have 30 psi oil presure. I did not replace the oil pump.IT calls for 50/60psi. Is 30 psi ok turning with starter.Thanks for any help.
Randy in NE
09-30-2005 08:46:43
 Re: super oil pressure in reply to wanabefarmer, 09-30-2005 08:31:09
I would say that if you are getting 30 psi on the starter then you are in good shape. With the engine running and up to operating temperature you should probably see 60-70 psi. You do want to be careful so that you don't spin the starter too long on 12 volts. You could burn it up.
wanabefarmer
09-30-2005 08:34:00
sorry subject should be Super A
