!!! HELP !!! H Gasket Set What the Heck Is This???
MagMan
10-01-2005 13:47:04
OK This one has got me and that seems to be pretty easy these days. Ok I have a Victor Reinz Gasket Set for a u164 or C152 Ok does any one know what this stough is Crank shaft dust seal,Crank shaft rear oil seal retainer Ret. Plate, Generator conecting rod Housing, 1 Gear cover, 1 Gear cover (1/32),1 mag bracket, 1 mag bracket (1/32),What are the 1/32" gaskets for? it also says 1 water pump seal, 1 water pump body,1 water pump outlet elbow,They also included 2 oil pump cover gaskets, Is this for shimming or something They are both the same size, My pump now has one andI had it checked at the machine shop he said it was really good. Why would you shim it farther apart from the pump gears by using 2 gaskets ? I dont know maybe this is all elementary and I am just to stressed these days to figure it out. But any help would be appreatiated. JON
Nebraska Cowman
10-02-2005 06:13:13
 Re: !!! HELP !!! H Gasket Set What the Heck Is Thi in reply to MagMan, 10-01-2005 13:47:04
You are too stressed Jon. The rule is "Only use the silverware you know what is for and leave all the other extra eating utensels lie on the napkin".
CNKS
10-01-2005 17:51:40
Without looking up the specs, the pump is supposed to have a certain amount of clearance, thus you can stack gaskets. Leave it alone if it works ok, if you want to disassemble and clean, then put a single gasket back in -- If the machine shop guy said it was ok just leave it alone, unless you actually have a way to check the clearance.
