Super M Oil Pan Gasket
David Kronwall
10-02-2005 04:23:54
My "new" "53 Super M has oil seepage around the oil pan, so I plan to replace the gasket. Any tips for doing this? Should I use some type of gasket sealant or not? Thanks!
Phlogiston
10-02-2005 06:36:57
 Re: Super M Oil Pan Gasket in reply to David Kronwall, 10-02-2005 04:23:54
When you get the pan off, make sure to tap the bolt holes back to the original shape. They can get distorted after a guy tries to over tighten them to stop a leak.
Phlogiston
Yugrotcart
10-02-2005 05:12:37
I replaced the gasket on my W6 for the same reason. I used sealant on the pan side only, that way removal in the future is easier. Shouldn't have to lay on my back trying to remove the old gasket from the block.
Jimmy King
10-02-2005 04:48:50
Yes, I always use permitex. It has been a few years so there may be something better.
Janicholson
10-02-2005 06:48:52
 Re: Super M Oil Pan Gasket in reply to Jimmy King, 10-02-2005 04:48:50
Hi-Tack bruish on, pan only
JimN
