15-30 Belt Pulley Keeps Turning
Loren in Iowa
10-02-2005 07:24:46
Why does the belt pulley on our 1925 15-30 turn, slowly, even when the pulley lever is disengaged. Seems to work, normally, when the lever is engaged. If I could get it to stop, completely, it might leak less grease.
ejr-IA.
10-02-2005 09:18:13
 Re: 15-30 Belt Pulley Keeps Turning in reply to Loren in Iowa, 10-02-2005 07:24:46
Stiff old trans lube makes a drag on the shaft
jostev
10-02-2005 16:54:01
 Re: 15-30 Belt Pulley Keeps Turning in reply to ejr-IA., 10-02-2005 09:18:13
I have the same thing happen with my H, if you grab it it stops and a little later it starts again, don't know if that the same with the 15-30. Jostev
