hydraulic pump capacity on 300U
ron bond
10-02-2005 16:08:34
I'm putting a loader on my 400U, no easy task. The tie rods must be bent to go through the loader bracket, and now I either mount an external front pump on the front pulley, or use the existing hydraulis-which are strong. Ouestion is, are the hydraulics good enough to power a loader, with 2 way cylinders? Anybody know the pressure and volume of the 300U pump and will ift work? I have two rear remotes for a log spliter, can I tap into them to power the loader and still have them for the splittr/
thanks-ron
PAULIH300
10-02-2005 16:47:34
 Re: hydraulic pump capacity on 300U in reply to ron bond, 10-02-2005 16:08:34
The pump ability isnt bad,but the fluid storage capacity is pretty feeble what with only the under seat reservoir.A lot of loader attachments back then put a big square reservoir on the front loader frame or on the side of the clutch housing.My U34 loader starts depleting capacity at 3/4 lift,and I have slightly overfilled the reservoir.
the tractor vet
10-02-2005 16:12:22
Around 1250 if the system is good and about 12 GPM.
PAULIH300
10-02-2005 16:12:00
A 400U? Or was that a mis-type?
ron bond
10-02-2005 16:19:44
 Re: hydraulic pump capacity on 300U in reply to PAULIH300, 10-02-2005 16:12:00
mistype-300U
the tractor vet
10-02-2005 16:11:25
PAULIH300
10-02-2005 16:11:25
