Farmall M engine numbers
Flatlander
10-02-2005 21:11:30
I have 2 farmall M tractors that the serial number does not match the engine number. My H numbers do match. I thought that my 44 M was all original. Did all of the Farmall M tractors have numbers matching blocks when they left the factory?
RustyFarmall
10-03-2005 06:37:00
 Re: Farmall M engine numbers in reply to Flatlander, 10-02-2005 21:11:30
Wayne is correct, some of them matched, some did not. You might want to compare the various casting codes, they will not all match either but if they are somewhat close then I think you could safely assume that the engine is original.
Wayne Swenson
10-02-2005 21:16:05
H numbers usually matched; M numbers did not match. Why I do not know.
