Pistons in an H
MikeF
10-03-2005 18:53:43
What is the largest size pistons I can put in an H. is that with or without sleeves. do I have to have sleeves in the block. I heard you can put 350 pistons in an H. Does the block need bored for 350 sleeves or will they fit?
ChadS
10-05-2005 11:08:30
 Re: Pistons in an H in reply to MikeF, 10-03-2005 18:53:43
With out the sleeves, you can run the 3-9/16 bore Super H pistons, use the 350 head gasket and run it. ChadS
FarmerSid
10-04-2005 04:40:35
You will have to bore the block a bit for the 350 kit to fit. Bore it a bit to accept the 350 sleeves. You will notice a big difference in your H with a 350 kit installed.
Cheers!
Sid
