FARMALL B SERIAL NUMBER
chris dirksen
10-03-2005 19:10:16
trying to figure out the year made and read contradicting info. Have four numbers on this farmall B ...chassis # 8638DB, block # 023J, Transmission # 6832DA, seat bracket # FAB 49686 15 40. Can anybody help me out on the year made?
CNKS
10-03-2005 19:35:56
 Re: FARMALL B SERIAL NUMBER in reply to chris dirksen, 10-03-2005 19:10:16
49686 is the serial number, the rest are part numbers.
Dave H (MI)
10-04-2005 06:52:42
 Re: FARMALL B SERIAL NUMBER in reply to CNKS, 10-03-2005 19:35:56
Yup...that's the serial number alright. Think the question was about the year made and that, according to my chart, is 1941. Remember though that these little Farmalls, like the N Fords, could have had parts swapped back and forth. Many parts are interchangeable with the A and some even with the C. Looking for other clues, like the year of casting codes, etc will help you gain support for the year. Some of the guys here can tell you where to look. There should be a stamped serial number near the #1 cylinder on the right side that will match your seat number. That is a good clue. Also, their is a casting code for the block, I believe, that references a date of manufacture. If you get enough numbers to match up then I would say you are good to go with 1941. Sound like I have done this recently?
Guess so!
