FARMALL Bolts-w/dot
courtland
10-04-2005 11:17:17
Just wondering if the dot on the endns of the bolts used on a 1950"s CUB is trademark thing or just part of the manufacturing?
RustyFarmall
10-04-2005 11:26:23
 Re: FARMALL Bolts-w/dot in reply to courtland , 10-04-2005 11:17:17
Actually I think it was a part of the manufacturing, when the operator parted it off on the lathe it left that little dot in the middle. BUT, since IH is the only maker to have that dot, it is a trademark also.
randy hall
10-04-2005 20:16:48
 Re: FARMALL Bolts-w/dot in reply to RustyFarmall, 10-04-2005 11:26:23
bolts are formed from wire not pressed or forged. the dot was made in the die of the cold forming machine for identification purposes.
Andrew Z
10-04-2005 13:42:22
When did they stop the dots on the bolts and put "IH" on the bolts? My 53 Super C has the dot and my 55 100 has the IH on the bolts. Andrew
Nat
10-04-2005 13:52:48
 Re: FARMALL Bolts-w/dot in reply to Andrew Z, 10-04-2005 13:42:22
They probably started making forged bolts in 1954 for the 1955 production run, but you probably figured that was the case anyway, right?
From what I've learned from a machinist friend, I would dare guess the bolts were turned from hex stock on a lathe, either by hand or in an automated process. Newer bolts are forged in a press using round stock, I believe.
