M oil filter and engine capacity
Sam F.
10-04-2005 15:15:24
Anybody tell me the oil filter number for my model M ?? Capacity of engine with filter change ?? How about trans and rear end ?? Kind and capacity of oil ?? Thanks
Billde
10-05-2005 05:40:41
 Re: M oil filter and engine capacity in reply to Sam F., 10-04-2005 15:15:24
Sam, use 90 wt gear oil in the trans sorry can't remember how much. Just fill to the check plug.
El Toro
10-05-2005 06:00:06
 Re: M oil filter and engine capacity in reply to Billde, 10-05-2005 05:40:41
The transmission and differential will hold 52
quarts if this is a refill. Hal
PS: That's a lot of gear oil 13 gallons.
El Toro
10-04-2005 16:31:22
Try NAPA auto parts for your filter. Engine holds 8 quarts of oil. Hal
To SN FBKM 59393 uses filter number 1155
From SN FBKM 59394 & up uses filter number 1125
El Toro
10-05-2005 05:51:18
 Re: M oil filter and engine capacity in reply to El Toro, 10-04-2005 16:31:22
Any auto parts store can cross-reference those numbers to Fram, Purolator or any major filter
manufacturer. Hal
David Kronwall
10-05-2005 04:36:08
Question for El Toro...are these same part numbers for my '53 Super M? Just trying to learn something from all the expertise I see on this site. You guys are something else. That's a compliment.
El Toro
10-05-2005 05:47:56
 Re: M oil filter and engine capacity in reply to David Kronwall, 10-05-2005 04:36:08
The Super M uses filter No 1125 from NAPA or 51125
from Wix filters. Hal
David Kronwall
10-05-2005 18:34:15
 Re: M oil filter and engine capacity in reply to El Toro, 10-05-2005 05:47:56
Thanks, El Toro, for the help. I appreciate it. By the way, a farmer friend of mine is restoring a 1947 M. Just found that out today (when I asked him about a place to house mine for the winter). He asked if I could help him out when it came to getting answers on the Internet. I told him about this great site. He said he wasn't too cool with computers, so I'm sure I'll be asking some questions about M's in his behalf. Actually, one of his questions comes to mind. His M has the small inset at the bottom of the radiator grill missing. He asked what this inset was for. I read about it somewhere but could not remember the answer. Can you tell me? I'll pass it along. Thanks, in advance.
El Toro
10-06-2005 04:54:57
 Re: M oil filter and engine capacity in reply to David Kronwall, 10-05-2005 18:34:15
You should put that question on the Farmall forum.
These tractor restorer's will know exactly what
the part is that's missing in the grill. Hal
David Kronwall
10-06-2005 05:22:46
 Re: M oil filter and engine capacity in reply to El Toro, 10-06-2005 04:54:57
Thanks. I"ll do just that.
El Toro
10-05-2005 07:53:21
filter numbers to Fram or any other name brand filters they carry. Hal
ChrisL
10-04-2005 15:17:30
That’s weird I just posted the same question for my H
