starting problems
nickledanddimed
10-04-2005 18:49:04
i sometimes have to losen the starter to start my 300 u IH its like its grounding itself out
Bob
10-04-2005 18:54:20
 Re: starting problems in reply to nickledanddimed, 10-04-2005 18:49:04
No doubt the starter drive ("Bendix") gear is jamming against the flywheel's ring gear teeth.
Possible causes...
Worn starter drive and/or starter bushings.
Worn or damaged flywheel ring gear teeth.
(Some units just like to do this once in a while, to be aggravating, without ANY apparent cause!)
Janicholson
10-05-2005 14:22:09
 Re: starting problems in reply to Bob, 10-04-2005 18:54:20
Bob has it correctly. Sometimes putting the trans in High gear, and rocking violently back and forth on the rear tire. When you have hadenough of it, replace the bushings and pinion first.
JimN
