Postive or Negative Ground ?
iester
10-04-2005 20:37:53
I have a 1957 IH 350 Utility Tractor. 4cylinder 175 cid gas.I am Reinstalling Wiring harness and noticed all wiring diagrams{in book}show Postive Ground is this correct? It is 12 volt, has generator and voltage regulator,12 volt coil no resistor
JLE
10-06-2005 00:11:11
 Re: Postive or Negative Ground ? in reply to iester, 10-04-2005 20:37:53
I stand corrected, they changed to twelve volts at serial # 14600 for gas engines. LP gas and diesel used 12 volt system.
Sean in Calgary
10-05-2005 10:30:11
My 1957 350 U (s/n - 7210S) is a 6v positive ground.
Not sure if that helps.
JLE
10-05-2005 03:52:58
I belive the 350's came with a 12 volt system, which would make it a neg. groung system.
Janicholson
10-05-2005 09:25:57
 Re: Postive or Negative Ground ? in reply to JLE, 10-05-2005 03:52:58
Our 1957 350ute gas was 6 pos. ground. There were many Letter and XX0 diesel tractors with 12 v pos ground factory generator systems. I don't know why IH kept the 6v on the gas units. It seems like a mediocre idea. A nice original looking system uses 12v pos ground generator/reg. (I like alternators they are near maintenance free and top up the battery well).
My 2 cents JimN
Nat
10-05-2005 05:04:40
Not necesssarily. I believe IH was still producing positive ground systems up through 1958. The 460/560 series tractors were the first negative ground in 1959.
My dad's 400 is a 12V positive ground.
Van in AR
10-04-2005 20:58:46
It was originally POS ground and if you have a POS ground regulator, you should wire it back pos ground. The generater does not care as long as its flashed after installation. Pos ground, the + on the coil goes to the distributor, and the amp meter is wired to read correctly.
Van
iester
10-04-2005 21:20:48
 Re: Postive or Negative Ground ? in reply to Van in AR, 10-04-2005 20:58:46
Can't rembember if battery + went to frame or starter?How do you tell if voltage reg is + or negative?
Van in AR
10-04-2005 21:26:29
 Re: Postive or Negative Ground ? in reply to iester, 10-04-2005 21:20:48
The voltage reg should be marked, maybe a sticker on the back. If not you may need to check the part number with a napa store or IH.
Van
iester
10-04-2005 21:39:56
 Re: Postive or Negative Ground ? in reply to Van in AR, 10-04-2005 21:26:29
Thank's Van So if it's a postive voltage regulator,Battery + goes to starter and Battery negative goes to frame ?
jimmer
10-05-2005 04:51:09
 Re: Postive or Negative Ground ? in reply to iester, 10-04-2005 21:39:56
Positive ground means just that. The positive battery cable goes right to the frame (gound). The negitive battery cable will likely go to a starter switch and then to the starter as well as the regulator.
