cut off rims
Farmallh1941
10-05-2005 13:44:14
I purchased some cut-off rims for the farmall h, they came off of a 1941. Question is which way are they supposed to go, If I put them on the way they are mounted, with the wheel extended to the end of the axle, it is about a foot further in than a regular rim on the axle. Is this right?
Also was there a specific purpose to these kind of rims? Thanks
russ hamm
10-05-2005 16:11:50
 Re: cut off rims in reply to Farmallh1941, 10-05-2005 13:44:14
as a lot know by cutoff rims he means they were cut off steel wheels with rubber tire rims welded on. cutting the axle like jimn mentioned reminds me of a story. my boss collected some tractors years ago and he had a minne u row crop with one axle longer than the other by quite a bit.he told us that the long axle must be wrong and we should cut it off as long as the other one. one of the guys tried to torch it off and then grind it smooth, but it would not cut. he showed me what looked like a hacksaw cut on the axle where someone had tried this before. that night i looked at some m&m tractor books and realized that that was a beet tractor! that axle stayed like it was. russ
Dave_Id
10-05-2005 15:02:18
When manufactured, the rims were steel, when rubber became more readily available, many farmers cut off the steel, and welded the rims so they could use rubber tires.
Janicholson
10-05-2005 14:32:23
I don't know the cut off term. But wheels and rims can be mounted in a variety of ways (except for the tread pointing backwards on the top of the tire) they are all operational and set for specific purposes, including being narrow enough to load on a trailer. Set them the way you think looks best and works for your applications. Row crop width, loader work, barn doors, stability on hills and wheel track mark location are all reasons for placement. The only tactic not recommended by me is to set them in as far as possible. this causes roll over to be so easy that operation can be dangerous in fifth, or on modest hills. Cutting off the axle stubs to make the whole tractor width narrower probably won't gain points on this forum.
two cents.
JimN
moseed
10-09-2005 07:38:07
 Re: cut off rims in reply to Janicholson, 10-05-2005 14:32:23
Farmallh1941,
Bolts turned out or in, depending on your need for the offset on your rims and the tread situated so when the print (arrow kinda thingy) is left in the soil it points behind you, where you are coming from. The open part of the tread print (arrow kinda thingy)should face the direction you are going.
