What model sicle mower?
TRF Jim
10-05-2005 19:07:05
When I bought my 300u I got a 2 point 5' sicle mower with it. I need some bearings and the dealer can not find the mower model #.
The drive on it goes from a pulley driven by the pto to a pulley immediately beside a counter weight that has the pitman arm attached. The dealer looked at many models but none were set up this way.
Thanks for reading and any help is welcome.
El Toro
10-07-2005 09:16:21
 Re: What model sicle mower? in reply to TRF Jim, 10-05-2005 19:07:05
You should post a picture of that sickle bar mower. Someone be able to identify it.
That 300 would handle a 7-ft sickle bar and it may handle a 9-ft. We used a 7-ft on an H and 300. I had a man to mow a field for me and he used a 9-ft sickle bar. Hal
Joe Kimbriel
10-06-2005 11:20:02
Pull the bearing or bearings out, look for a number on them and call around. If you take the bearings to a good bearing shop thay can match them up.
TRF Jim
10-06-2005 16:06:48
 Re: What model sicle mower? in reply to Joe Kimbriel, 10-06-2005 11:20:02
The problem is that the guts are gone from the housing, and I am trying to rebuild it. Therefore, no old bearings.
I think that I have found the balance of the parts so it will work.
