Farmall 656 disl can't keep it running???
Country_24605
10-06-2005 18:55:30
I have gotten a 656 farmall and about 2 weeks ago we was putting up hay when it started actin up and quit. ever since then it will run about 10 seconds or less like it ain't getting no fuel so i sent off the fuel pump to have it rebuilt or to see if there was anything wrong with it well i got it back about 3 days ago and changed fuel filters and everything got everything back in time and got all the air out of everything but same ol story and before i put the new pump on i did drain the tank and put different fuel in it incase there was something in it..... so i worked and worked for about 2days on it and still puzzled oh and my #1.#5.#6. injectors work they will shoot fuel.. #2 injector might get 4 drops from it and #3&4 nothing comes out and the lines are not stopped up? The pump was supposed to have been rebuilt but now i am woundering????? Any help would be greatly helpful.. anything else it can be or might try?
Brian in Ne
10-08-2005 11:01:27
 Re: Farmall 656 disl can't keep it running??? in reply to Country_24605, 10-06-2005 18:55:30
Might want to make sure that the return line to
the fuel tank is not plugged up. Same with the fitting coming out of the top of the pump. If either of these are plugged it will not let the pump work.
country_24605
10-09-2005 18:04:55
 Re: Farmall 656 disl can't keep it running??? in reply to Brian in Ne, 10-08-2005 11:01:27
It was in the return fuel line where it hooks into the fuel tank was all clogged up... we got it runnin like new..... Thank's for everyone's help on gettin this thing going again..
Allan in NE
10-07-2005 04:08:53
How about that fuel feed line between the fuel filter and the pump?
You're starving for fuel somewhere.
Allan
country_24605
10-07-2005 07:06:28
 Re: Farmall 656 disl can't keep it running??? in reply to Allan in NE, 10-07-2005 04:08:53
I have gotten a brand new line cause i thought when the fuel pump was working it was pinching the line and not letting no fuel threw.....
Mike i checked all of it once but i"ll go back and check all of them again to make sure..
country_24605
10-07-2005 09:43:09
 Re: Farmall 656 disl can't keep it running??? in reply to country_24605, 10-07-2005 07:06:28
All of my lines are good i took each of them off and cleaned and blew them out but still does the same thing like 3 are getting fuel good and the other 3 ain"t doing nothing. i drained the tank with the line that connects from the fuel filter to the fuel pump and it runs out great but when you hook it up to the fuel pump it"s like it can"t get fuel to them other 3?????
mike_r
10-06-2005 19:44:26
Are you 100% certain there isn't any blockage between your fuel tank and filter? I encountered a similar problem on a telescoping forklift where a bee had gotten in the fuel tank and clogged the line. Drained the tank, replaced the filters, fuel pump, injector pump, the works...all for a simple bee. It was a four cylinder and two of the four would spurt fuel. Might be something worth looking into.
