Need Help 574 Int.
cowboy rick
10-06-2005 19:07:53
Just purchased a 1978 574 dsl seems to run good, but is smoking white smoke, and spraying fuel from the exaust. A electric fuel pump was added, could this be pushing to much fuel to the injectors.
Any ideas thanks
cowboy rick
10-07-2005 03:10:31
 Re: Need Help 574 Int. in reply to cowboy rick, 10-06-2005 19:07:53
Thanks for the info. This is a much newer machine than i'm use to working with. Does the drive clutch work off the hyd. system? clutch is slipping in higher gears. I've tried to adjust the linkage, but has not helped. Thank you again.
JRD(VA)
10-07-2005 06:14:13
 Re: Need Help 574 Int. in reply to cowboy rick, 10-07-2005 03:10:31
Make sure its fuel and not water, no reason for a fuel pump, clutch is not hyd, can take inspection plate off bottom to make sure release bearing has clearance. Saddle tank is prone to collect sludge at bottom, might have put fuel pump on because lines and tank fittings became clogged, might need to blow out lines and fittings.
MJ in the UK
10-07-2005 02:44:47
Just a nother thought the electric fuel pump wich it should not have may be making the thermostart valve leak as it would be putting pressure at the valve. MJ
MJ in the UK
10-07-2005 02:22:03
Hi JB2 you have coverd this problem very well.Just a thought but when we sold these tractors new we had a similer problem. It turned out to be a faulty thermostart valve in the inlet manifold. The thermostart unit is activated by holding the ign key in the heat position. This heats a glowplug and then a valve opens up to let fule in wich the glowplug ignites. If the valve in the thermostart unit is faulty this could be the problem. MJ
Nat
10-06-2005 20:08:00
The electric fuel pump was added to "cure" some perceived problem with the tractor. It probably has no real effect on the tractor, because the injector pump regulates the pressure to the injectors.
JB2
10-06-2005 19:56:25
Hi Rick, the 574 only had a gravity feed to the injection pump. Starting with the simple things first check that the STOP/START/RUN lever to injection pump is working properly. See picture
at this website:
Link
The top lever on the side of the injection pump is the throttle, the bottom lever is the STOP/START/RUN control. The picture shows it in the RUN position. The START position is when the lever is just touching the plunger, the STOP position is when the lever is against the STOP adjustment with the plunger completely depressed.
Another problem is the thermostat is not working properly and the engine is not up to running tempature. If the engine is to cold it will not burn the Diesel fuel properly and will blow white smoke and slobber(raw fuel or black oily substance running down exhaust manifold, inside muffler etc.). Next is someone adjusted the RUN stop adjustment screw on the injection pump. With reference to the picture on the web site, the RUN stop screw adjustment is in the position for a 684 putting out about 62 PTO HP. If the RUN stop adjust screw is backed off so the STOP/START/RUN lever hits the holding bracket for the RUN stop adjust screw then the engine will be over fuelled and putting out about 70 PTO HP and will again blow white smoke and slobber when idling about.
One solution is that when your engine is idling around don't pull the STOP/START/RUN lever all the way to the top, leave it down a 1/4 inch or so. This will reduce the amount of fuel injected to the cylinders.
Another cause could be that the injection pump is timed to slow.
The D239 is an excellent engine and will run a long time given normal maintanance.
Hope this helps, please repost when you find solution.
JB2
