M motor stuck
bfinohwa
10-07-2005 15:52:33
I put a bunch of tranny fluid in the spark plug hole and let it sit for a week. When I put the tractor in gear it rolled across the floor of my shop and the motor never budged. If the motor was still stuck then the tractor should have locked, it didn"t. I tried several gears and the tractor just rolled back and forth with ease. I engaged the pto and it spun as the tractor rolled. Any ideas about whats wrong?
wayne2
10-07-2005 21:06:07
 Re: M motor stuck in reply to bfinohwa, 10-07-2005 15:52:33
Check following posts. I had _ell of a time getting pistons and sleves out of my stuck M aftercouple days and a little broken casting replaced a 100.00 a hole G-luck Wayne
Sonny Reese
10-07-2005 17:20:43
Check input shaft between clutch and trans there is a coupling in there that can break or fall apart.
El Toro
10-07-2005 16:29:23
Are you sure the clutch is engaging or if the tranny shifter is shifting the gears into gear?.
The wheels would slide when the engine is stuck
if you were to pull it. Hal
