DRIVE TRAIN NOISE
PA. FARMER JOH
10-07-2005 21:28:03
i have a thump,thump,thump in the drive shaft from the clutch to the rear. it seems louder at the rear then it does at the clutch end so i feel it is ressonating forward. any one have this problem before ? it does it in neutral !!! sounds like a gear box that has a gear with a few teeth missing on it. never had one apart so i don`t know what to be looking for. if anyone has had this problem and can help me in trouble shooting it i would appreciate all help, thank you.
RustyFarmall
10-08-2005 05:01:16
 Re: DRIVE TRAIN NOISE in reply to PA. FARMER JOHN, 10-07-2005 21:28:03
An H or an M will do that when the driveshaft bolts are not completely tight. Don't know what tractor youe have.
williamf
10-08-2005 04:52:13
It does it in neutral - does it stop when you depress the clutch?
And what model tractor?
Wm
