Model of H generator
'52 Farmall H
10-08-2005 09:05:30
What model generator was used on the Farmall H? The data tag on mine seems to have been sanded mostly unreadable during a past repaint.
Is this generator used on the other 6v IH tractors?
Thanks.
Bob M
10-08-2005 09:52:17
 Re: Model of H generator in reply to '52 Farmall H, 10-08-2005 09:05:30
Delco part #1100501 (IHC part #354 237 R91) is one good number. It was used on gas Farmalls from the A thru the M, also on the McCormick W series - both regular and "super". Several other Delco generator numbers were used as well and will interchange.
RustyFarmall
10-08-2005 09:14:23
The generator is a Delco-Remy, don't know the model number. The same generator was used on so many different IH tractors it would be almost impossible to list all of them, and with the exception of the pulley, I think you might be able to find the same generator on several competitor tractors.
