Changing milky trans fluid
Wisconsin 560G
10-08-2005 10:17:05
Gentlemen,
Thanks to your advice we have concluded I have moisture/condensation in the trans/hydraulic fluid in my Farmall 560G. I am going to have to change the fluid and replace it with new.
Here is my question: How do I make sure all the old fluid gets purged from the system before new fluid is put in? I don't want to contaminate the good fluid with moisture laden fluid.
Any advice will be greatly appreciated.
Thanks, John
Don L C
10-09-2005 20:04:08
 Re: Changing milky trans fluid in reply to Wisconsin 560G, 10-08-2005 10:17:05
Run the tractor around the barn yard with 5 gal.fuel oil as a rinse..... drain and refill with proper gear oil..... ..
Wisconsin 560G
10-10-2005 14:56:00
 Re: Changing milky trans fluid in reply to Don L C, 10-09-2005 20:04:08
That sounds better than my first bit of advice.
Thanks!
the tractor vet
10-08-2005 10:50:28
Ya can't get it all out unless ya tear the whole tractor apart and clean everything that ran in the hdy. fluid the best ya can do is drain the all the drain plugs and lines that you can get off and let the transrear end drip and blow the lines out and use a good hdy oil and change the filter often and keep the tractor under roof .
