H rear tires 11.2 or 12.4 x 38 ????
Sam F.
10-08-2005 19:18:32
My Farmall H has 11.2 x 38 inch rear tires. Can I put 12.4 x 38 on it and they work fine ??? Have 10 inch wide wheels.
Jeff In Ontario
10-09-2005 10:58:06
 Re: H rear tires 11.2 or 12.4 x 38 ???? in reply to Sam F., 10-08-2005 19:18:32
Sam:
You"d be fine with the 12.4x38 tires...I put those on my H this spring and they really work well.
Jeff
Leroy
10-09-2005 07:46:31
The early H had 10" or new number 11.2 tires while later H's I think came out with the 11" or 12.4 tires on same rims. our 41H was orignal the 10" but we had the 11" or later the 12.4 on it. The very first h's had a 36" rim instead of the later 38" and if orignaly could have had any width rims put on. The duals I had for one tractor and were 8" rims with 13.6 tires on them and worked OK, rim width is not as critical as some think, the biggest difference is between 11.2 and 12.4 is ground speed and unless you are doing something that reguires PTO in low gear and a very low ground speed you will be OK with the bigger tire, you could even put 13.6 tires on but will lower pull power in same gear and will increase ground speed so depending on what you are doing will determine the size of tire you need
Steve Fellows
01-08-2008 06:28:25
 Re: H rear tires 11.2 or 12.4 x 38 ???? in reply to Leroy, 10-09-2005 07:46:31
I wanna buy 11.2 X 38 inch rims for the tractor my kids are restoring up. So just send me an email back.
Sincerely,
Steve Fellows
old
10-08-2005 21:40:38
I have an H with 13.6X38 on it so the 12.4 will work out good.
CNKS
10-08-2005 19:26:51
Yes, 10 inch rims were designed to be used with 11 inch tires. 11-38 and 12.4-38 are the same tires.
farmallguy3
10-08-2005 19:21:22
I believe it would be alright my H HAS 12.4X38 on it.
Andrew Z
10-08-2005 20:01:23
 Re: H rear tires 11.2 or 12.4 x 38 ???? in reply to farmallguy3, 10-08-2005 19:21:22
I have the 12.4 on my H but the rims came off a Super H not sure if that made a diffrece. Andrew
