charr-lynn
tn terry t
10-08-2005 21:37:40
can anyone give me the part number for the charr-lynn power steering unit for an farmall h
jossette
10-09-2005 06:44:21
 Re: charr-lynn in reply to tn terry t, 10-08-2005 21:37:40
part #_____ _____ description_____ _____price
217-1015_____ _____ S101-F_____ _____ _$392.08
217-1020_____ _____ S102-F_____ _____ __$408.72
specifications_____ ____S101-F_____ _____S102-F
torque at 100 psi_____ _700 in lbs____1100 in lbs
rated pressure_____ ____1000 psi_____ __1000 psi
max speed @ 3 GMP_____ __108 RPM_____ ___65 RPM
recomended fluid input____2.5-3 GPM_____ __3-4 GMP
jossette
10-09-2005 06:46:16
 Re: charr-lynn in reply to jossette, 10-09-2005 06:44:21
the torque spec is 1000 psi and not 100 psi
tn terry t
10-09-2005 10:43:25
 Re: charr-lynn in reply to jossette, 10-09-2005 06:46:16
hey there jossette if you remember i talked to you about live hydro on an H well i got it woking it will throw those 1500 lb hay rolls around like a beachball ill bet you can you can guess what my problem is now thanks for the information!!!!! !!!!! !! terry
jossette
10-09-2005 15:53:56
 Re: charr-lynn in reply to tn terry t, 10-09-2005 10:43:25
Not enough tire pressure in the front???
tn terry t
10-09-2005 19:15:42
 Re: charr-lynn in reply to jossette, 10-09-2005 15:53:56
not enough arm pressure left buddy lol where did you get those part numbers from ? also how much air pressure is right my two new front tires are written in china talk
jossette
10-09-2005 20:07:44
 Re: charr-lynn in reply to tn terry t, 10-09-2005 19:15:42
send me an e-mail
40- 45 lbs. when lifting
