9 Bolt Hubs for H-350 axle?
migraine
10-09-2005 14:39:52
Looking for ideas of what other model tractor or aftermarket 9 bolt hubs will fit on H-350 series. I see some running pressed wheels but I can't seem to find the right size key to fit the Super H. Or do you buy the centers and build up from there. Maybe Oliver or MM had some that interchange? Thanks Migraine
migraine
10-10-2005 15:15:18
 Re: 9 Bolt Hubs for H-350 axle? in reply to migraine, 10-09-2005 14:39:52
Thanks for the help guys,I've found a set of each of these with a few phone calls today. Will take some measurements in the next few days. Migraine
RustyFarmall
10-10-2005 05:35:42
I think you are on the right road with the Oliver or MM hubs. Not positive on it though.
ChadS
10-10-2005 11:15:54
 Re: 9 Bolt Hubs for H-350 axle? in reply to RustyFarmall, 10-10-2005 05:35:42
Ollie 77 hubs work, you will have to cut the key width down on the 77 hubs to fit the H axle. MM Z hubs bolt right on, but kinda weak in the key, Ive broke 2 sets of the Z hubs on my 100+hp H, went to weld on hubs. Chad
