Another 350 water pump...am I up a creek?
Bill46
10-10-2005 05:17:26
I have the same problem as Tim, but my 350 is a diesel. I finally got it running yesterday. I put all new fuel filters on it, cleaned the water seperator, cracked the injector lines till it spit fuel and she fired as I tightened the injuector lines. Now I see the water pump has a lot of play in the shaft and the gasket is leaking a little.
Anyone know where I can find a new or rebuilt one? This was dad's old tractor and I hate to get rid of it.
The engine runs really good...but I am aftaid to run it with a bad water pump.
Think it would help to run a wanted add in the clasified?
Thanks in advance guys.
T.B.W.
10-10-2005 06:46:25
 Re: Another 350 water pump...am I up a creek? in reply to Bill46, 10-10-2005 05:17:26
check with Mike at Steelwheelranch.com good guy to deal with
El Toro
10-10-2005 06:23:58
If your Case/IH dealer doesn't have a kit as Rusty suggested, you should send an email to info@foleyengines.com to see if have a kit or pump. Hal
RustyFarmall
10-10-2005 05:41:29
You might want to check a Case-IH dealer and see about getting a rebuild kit. I've never done one, but the water pumps on these old tractors are designed so they can be rebuilt somewhat easily. They are not like the water pumps found on cars on trucks which require special tools and equipment for disassembly.
