Can you convert Super A to Kerosene
Gafarmboy
10-10-2005 06:09:53
Just a quick question to find out if it is possible to convert a gas 1954 Super A to Kerosene or other low octane fuels.
Thanks in Advance
Gafarmboy
gene (missouri)
10-10-2005 08:14:10
 Re: Can you convert Super A to Kerosene in reply to Gafarmboy, 10-10-2005 06:09:53
Anything is possible.
You will need to change the manifold to a duel fuel manifold, install a starting fuel tank and shut off valve, provide a T in the fuel line to the carburator. Carburator should work. You may have to install different pistons with a lower compression ratio some were around 4.5 or 5 to 1.
(1) The cost of kerosene or diesel fuel is as high as regular gas. (2)You will lose horsepower on kerosene.
My opinion. You will gain nothing by going to a duel fuel system.
Gene
Gafarmboy
10-10-2005 08:37:53
 Re: Can you convert Super A to Kerosene in reply to gene (missouri), 10-10-2005 08:14:10
Thanks for the reply Gene, I am not looking at this project as a money saver, I am looking more at being less dependent on one type of fuel. Plus I have two 250 gallon tanks, one I hope to use for Kerosene. If you have more detailed plans, or know where I might find them, please let me know.
Gafarmboy
