Farmall 140 plug
mitchp
10-10-2005 06:31:27
I finally found the tranny oil level plug for my 1966 farmall 140, but the problem is i can't find something to stick in there to turn it, i thought a 3/8" rachet would work but its too big, 1/4" is too small, anybody know the size i need?
CNKS
10-10-2005 17:25:52
 Re: Farmall 140 plug in reply to mitchp, 10-10-2005 06:31:27
1/2 inch drive will fit loosely, if it is the same as the Super A plug.
Hugh MacKay
10-11-2005 17:06:07
 Re: Farmall 140 plug in reply to CNKS, 10-10-2005 17:25:52
CNKS: Mitch is talking about the transmission fill to level plug, at front end and just below left fender. My SA has a square head pipe type plug, while my 130 and 140 do take a 3/8 drive handle to remove it. Someone must have switched the plug in Mitch's tractor. I basically accepted the fact, he take the suggestion for the 5/16 square stock.
mitchp
10-11-2005 05:12:56
i mean the plug under the fender on the left side of the tractor, the one you let the oil run out when its full
CNKS
10-11-2005 17:14:08
 Re: Farmall 140 plug in reply to mitchp, 10-11-2005 05:12:56
Yup, you did say oil LEVEL plug -- short circuit between eyes and brain.
scotty
10-10-2005 06:35:41
You might try a piece of 5/16" square stock.
scotty
