Will 88 Oliver hubs fit on Farmall M ??
Hank L
10-10-2005 10:55:55
I am planning on putting steel pressed wheels on the back of my M. If I am measuring it right an 88 oliver row crop hub should fit. Anyone know if this works? Or is there a better way of doing this? Thanks
Dave Sherburne,NY
10-11-2005 16:27:21
 Re: Will 88 Oliver hubs fit on Farmall M ?? in reply to Hank L, 10-10-2005 10:55:55
Its called a step key and a machine shop can
make it for you.
ChadS
10-10-2005 11:09:11
Same axle size, but the keyway on the oliver hubs have to be cut down to the M key way specs. Chad
Brad in WI
10-10-2005 11:38:31
 Re: Will 88 Oliver hubs fit on Farmall M ?? in reply to ChadS, 10-10-2005 11:09:11
Hubs off a Massey Harris 44? also fit. That is the donor for my hubs. you can also just make a key to fit the different size keyways. Brad
