What causes a bluish smoke when motor is hot, also
1066xx1
10-10-2005 16:50:56
I have a 1066. When pulling a heavy load it has a little pop in the motor, not bad like a valve, but not smooth either. When it idles after hot it will smoke a bluish smoke for a while but will quit after a few minutes. I have replaced fuel pump and injectors. Intervance in old pump quit. Does anyone have any idea what is causing this?
the tractor vet
10-10-2005 18:12:25
 Re: What causes a bluish smoke when motor is hot, in reply to 1066xx1, 10-10-2005 16:50:56
Do you have the pump timing where it is suppose to be ??. And when was the last time that you did a valve adjustment . How muck blow by does it have???? It is real had to make a jugement call over the magic box .
