Straighten me out here, . . .
Mitchissippi
10-11-2005 11:21:12
On a 1066 - is the PTO gear driven or hyd driven, or a combo of both? I know there is a PTO Drive gear behind/under the clutch. And a shaft from that gear back to the PTO unit. I also know that the PTO unit has a pickup tube. How's all this work?
Mitch
ACES
10-11-2005 11:27:05
 Re: Straighten me out here, . . . in reply to Mitchissippi, 10-11-2005 11:21:12
Mitch The PTO is gear drive off the same gears that drive thr hydraulic pumps but the clutch is hydraulicly operated off the pump on the PTO that is why there is a pick up tube, and has it's own valve to adjust the pressure for the clutch.
Mitchissippi
10-11-2005 12:58:16
 Re: Straighten me out here, . . . in reply to ACES, 10-11-2005 11:27:05
Thanks. I almost had it right in my noggin, but wanted to run it by you guys before I opened my mouth.
'preciate it!
