Hydraulic Parts
ACWD
10-11-2005 17:50:25
My hydraulic oil is leaking into my motor oil. Where is the best place to get the new seal or rebuild kit that I need. It is a "49 model. Any help would be greatly appreciated.
PAULIH300
10-11-2005 18:42:11
 Re: Hydraulic Parts in reply to ACWD, 10-11-2005 17:50:25
Bad pump seal.Its available at NAPA thru Chicago Rawhide.You probably also have a grooved pump shaft.Sleeve it with a Speedi Sleeve.You will need to disassemble and measure.Is it an H?
CNKS
10-12-2005 06:27:14
 Re: Hydraulic Parts in reply to PAULIH300, 10-11-2005 18:42:11
Unless it's an M&W pump conversion, it is a Cub, C, or Super A. If it has an o-ring, the shaft hole has to be enlarged to accept the speedi-sleeve.
