farmall m 5th problems
farmall junkie
10-11-2005 18:50:53
i have a 1944 farmall m and when i put itin 5th gear it wont stay in gear.the only way itwill isif you hold it there.after about 10 minon the road this stinks.any help on what the problem might be would be helpfull thanks mike
Ernest
10-12-2005 09:03:25
 Re: farmall m 5th problems in reply to farmall junkie, 10-11-2005 18:50:53
Could be anything! Worn parts?
I had fix 2 in the past few years first one was an M Jumped out of 5th gear. Shifter fork was fine so took off the platform (seat, gas tank, pulley, steering post, and other stuff) Shfting rails were good and the ball and detent spring was the problem, well the spring broke.
Second was a Super M jumped out af 5th and took apart and nothing broke (ball-detent spring), Nothing worn out but their was lots of gunk in their, The oil over the years built up a wax like substance and coated things. took many hours and lots of cleaner and problem solved!
Both have not had problems since!
Ernest
10-12-2005 09:02:53
JRD(VA)
10-12-2005 06:42:38
Might just be the detent ball and spring that holds shifter rail in place, take shifter out and move rail for 5th, if it slides easy from 5th position (no click or resistance) detent or notch in rail could be problem.
CNKS
10-11-2005 19:12:06
The gear and/or the shifter forks are worn -- requires taking off the transmission/differential cover. Many posts on this in the archives -- do a search.
