300 transmission
Levi Keech
10-12-2005 16:28:46
I need to fix 5th gear in my 300. Is there any way I can get to the transmission without having to take the whole back end of the tractor off? If I wanted to go in through the top it looks like I would have to take everything off clear up to the front of the gas tank? Please tell me there's an easier way!!!
Aces
10-12-2005 20:05:33
 Re: 300 transmission in reply to Levi Keech, 10-12-2005 16:28:46
Levi. Some one is going to have to say it so just as well be me. No short cut unless you use a torch. You will have to split the tractor at the back of the TA housing and remove the tranny deck. Now if you replace the sliding part of 5th only that will do it. If you need to replace both parts of the gear then you need to split at the clutch and the back of the TA. If you need to both splits do the clutch first then the back.
