smoking M
Lost in AL
10-13-2005 11:22:53
Hello I have a farmall M that the compression is 95 to105 but smokes like it has no rings . What should the compression be ? Lost in AL
Janicholson
10-13-2005 11:41:48
 Re: smoking M in reply to Lost in AL, 10-13-2005 11:22:53
That compression is fine for an M. They tend to be in that range normally.
Either rings or valve guides can allow oil to pass into the chamber and burn.
If it smokes consistently especially under load ---rings, either stuck, worn, or collapsed from and overheat.
If it smokes most going down hill on the road, or at idle, then cleans up a fair amount when worked ---Valve guides
Good luck JimN
Lost in AL
10-16-2005 17:29:03
 Re: smoking M in reply to Janicholson, 10-13-2005 11:41:48
thanks for the advice we took it apart today rings were weak like it had been hot.
