Hy-Tran Fluid
LLoyd in Conn
10-13-2005 16:03:28
Where in CT can I find brand name Hy-Tran ? Is the napa brand top shelf fluid a viable alternative ?
John in Ct
10-14-2005 15:53:22
 Re: Hy-Tran Fluid in reply to LLoyd in Conn, 10-13-2005 16:03:28
Kashita Equipment on Rt 5 in South Windsor has it on the shelf.
scotty
10-14-2005 04:38:10
Loyd, Im in Ct and I use Columbia Tractor in Claverack, Ny 518-828-1781. Order it in the morning and you will have it on your doorstep the next day. They are a Case IH dealer, and give very good service!
scotty
El Toro
10-14-2005 04:07:56
You could use Hy Gard hydraulic oil. Some that post on here have used it. Hal
kenr
10-14-2005 01:23:53
I know a lot of people will not agree with this, but I have been using non-detergent 30 weight motor oil in my hydraulic unit on my Super A for probably thirty years.
I'm in Florida, and don't use the tractor in winter much, so cold thick oil is not a problem.
Bob
10-13-2005 16:14:40
A "store brand" oil will likely be just fine if it meets the OEM spec's, but if you want the real thing, try the CNH dealer locator.
