I need Carb help BAD.What did I buy???
AC Hodges
10-13-2005 16:20:16
I bought a gem of a carb on E-Bay. Or so I thought. It is a zenith and looks just Like a 11115. The tag says 11188. I took it apart and it was in very good condition so all I did was put new gaskets on it. Didn't leak a drop( rare for me). Set the float a little high so it wouldn't run rich. Put it on my Super C cranked it it up and got black smoke at idle and a flutter at high Idle. Could not lean it out to save my life. If you put a load on it a high idle it seems to smooth out but gives black smoke. Will this carb work ? Does it need different jets? What did I Buy?
AC hodges
10-13-2005 19:53:23
 Re: I need Carb help BAD.What did I buy??? in reply to AC Hodges, 10-13-2005 16:20:16
Thanks for all the Input. When I said I raised the float I had my perspecttive up side down.(looking at it upside down on the bench) I did lower the float but only about a 1/32. I might try lowering the level a little more.Thanks for the cross reference and the pdf.
KEB
10-13-2005 18:35:05
Raising the float raises the fuel level in the bowl which can make it run rich. Also, check the needle valve - if it leaks, it'll run rich regardless of the float setting.
Don L C
10-13-2005 18:09:18
It seems to me that raising the float adds fuel to the bowl..... if it was me I would set the float at the correct setting..... if she is running black smoke, its flooding.....
CNKS
10-13-2005 17:08:51
You want the float set LOW if it runs rich, that is when the carb is right side up -- could be the jets though, as the others say.
Nebraska Cowman
10-13-2005 17:02:00
ya, should work. Check here. But who knows what jets might be in it? Sometimes stuff gets changed.
RustyFarmall
10-13-2005 16:31:07
I was just getting ready to do some cross referencing for myself, I'll see if i can find your numbers while at it.
RustyFarmall
10-13-2005 17:08:15
 Re: I need Carb help BAD.What did I buy??? in reply to RustyFarmall, 10-13-2005 16:31:07
According to what I found the 11188 was used on the U2 and U123 power units, which are basically the same engine as a C or super C, so it should work. I wonder if someone maybe drilled out the main jet trying to get more power?
