Who sells 140W Gear oil in New England?
djp
10-13-2005 18:51:13
Does anyone know where I can get some 140W gear oil in the Mass/CT/RI areas? I havent seen it anywhere.
Thanks
jason(ma)
10-14-2005 19:41:53
 Re: Who sells 140W Gear oil in New England? in reply to djp, 10-13-2005 18:51:13
not sure, never seen straight 140. Have you tried Napa and John deere? I get my bulk from Tarus Lubricants in Lowel mass and have gotten 85w-140 from them. If needed I can dig out their phone number. Other people buy from the Robin autoparts chain. Can you let me know what you find.
Dave in CT
10-14-2005 00:19:46
What are you using it for?
djp
10-14-2005 05:26:09
 Re: Who sells 140W Gear oil in New England? in reply to Dave in CT, 10-14-2005 00:19:46
I am putting it in my H. I am looking for straight weight also, not 85-140.
Dave in CT
10-14-2005 05:54:58
 Re: Who sells 140W Gear oil in New England? in reply to djp, 10-14-2005 05:26:09
If it's for what I'm guessing, a common solution to using a thicker lube to reduce or prevent leaking from an older H steering box (like mine) is to use John Deere Corn Head lube. It's got the consistancy of mayonaise and it flows into the gears better than a regular grease. I tried a regular grease and found, unless it's really hot, the gears just dig holes and you don't get a flow of lubricant. If the corn head lube leaks, it means you really need to rebuild the steering box.
djp
10-14-2005 07:54:46
 Re: Who sells 140W Gear oil in New England? in reply to Dave in CT, 10-14-2005 05:54:58
It is for the gearbox only...
CNKS
10-13-2005 19:45:10
Farm stores, or find a bulk distributer that sells to farmers, etc.
old
10-13-2005 19:44:25
Any good auto parts store should have 80W-140 oil on hand and if not they should be able to get it in 24 hours for you.
