806 brakes
retier
10-15-2005 05:18:27
on my 806 diesel, when applying brakes the first time you press pedal you have no brakes at all but press a second time you have good brakes, what is my loss of brake pressure?? any help
the tractor vet
10-15-2005 06:50:17
 Re: 806 brakes in reply to retier, 10-15-2005 05:18:27
Well before i get going this morning i'll try on this one , There are several places to look . (1) first Bleed the brakes , (2) what shape are the brakes in ??? you could have stuck adjusters and the pistons are cocked , It could be a stuck check valve (there are two) one on top of the MCV under the fitting on the crossover line and also on the brake valve , Flow divider sticking low pump output , sticking sump check valve, that one is in the lower righ hand corner behind the MCV , and on some rare occasions the brake valve it's self. Here again it would be nice if i could see it and check it myself.
stu in njo
10-15-2005 07:09:42
 Re: 806 brakes in reply to the tractor vet, 10-15-2005 06:50:17
Befor you get to deep into itbleed the the brakes if thats it you are done.If not start checking the rest of it. You say there good aftre 1 pump most likey air in system. hope this helps Stu
the tractor vet
10-15-2005 17:01:36
 Re: 806 brakes in reply to stu in njo, 10-15-2005 07:09:42
I think i said that .
retier
10-15-2005 18:41:16
 Re: 806 brakes in reply to the tractor vet, 10-15-2005 17:01:36
I have already bled the brakes, no air what so ever I'll look into the other suggestions , thanks to both of you for your input, hope I find the problem if not I'll be back to tell what I did and find out what else can be done
the tractor vet
10-16-2005 07:01:23
 Re: 806 brakes in reply to retier, 10-15-2005 18:41:16
I did not figure that you would find any .air
