806 d ?
stu in njo
10-15-2005 12:09:49
I think there is oil leaking from head gasket at #3 cyl can head be retorqued or is it head gasket time? thanks Stu
the tractor vet
10-15-2005 17:00:18
 Re: 806 d ? in reply to stu in njo, 10-15-2005 12:09:49
Like the other guy said but adding to it while it is off i would recomend that now is the time to do the head and have it refaced more then likely it needs it if it is leaking.so get the valves guides and seats and milled all at once and be done with it but remember to retoqure after you have it to operating temp and again at fifty hours.
stu in njo
10-15-2005 17:42:32
 Re: 806 d ? in reply to the tractor vet, 10-15-2005 17:00:18
Thanks for the info. I was hopeing not to have to tear it down at this time. I gess there is no way around it. thanks Stu.
max adams
10-15-2005 16:34:12
Stu in my opinion the head gasket needs to be replaced!
