M farmall blow by
Josh Johnson
10-15-2005 17:06:56
I have an M Farmall and some sort of wire mesh is coming through the blowby where the pipe connects to the block. What is it and what do I do with it?
RustyFarmall
10-15-2005 17:19:13
 Re: M farmall blow by in reply to Josh Johnson, 10-15-2005 17:06:56
That is the filtering media, to prevent dirt from getting into the engine if it would happen to breathe the other way. I think the pipe itself is bolted to the lifter cover, you should be able to unbolt the pipe and then you can see what's going on. The mesh belongs in the sort of square shaped part, not in the pipe.
Farmer Bob
10-15-2005 17:18:19
It is called packing and resembles a copper chore girl scrubbing pad that your Grandma used to use on pots and pans. You can remove the breather and soak it in kero/diesel and tuck it back into the housing or even replace it with a new chore girl if you want. It is probably deteriorated from age and started to come loose.
