Bearing number for differental shaft for A
Tiny TIm
10-16-2005 07:59:02
I have my father's "A" farmall and have used it around my house and garden for years. The right rear wheel bearing for the differential shaft is wore slap out. I can't get any numbers off of it. I pulled the left wheel off and removed the bearing cap off to try to see some numbers--no luck. Does anyone have the numbers for the bearing and a price I"m gonna haft to pay? Thanks for any help----- ----- ----- -tbird
CNKS
10-16-2005 09:06:41
 Re: Bearing number for differental shaft for A in reply to Tiny TIm, 10-16-2005 07:59:02
There are several bearings. The one called the differential bearing is the one that fits in the bearing retainer that bolts directly into the transmisson/differential housing. I.E. you have to remove the wheel and the drop axle housing to get to it. Number is ST 202. Any bearing place can cross it. Cost is likely $50-$100. The lower axle shaft itself goes thru inner and outer bearings. The inner is ST 205 A. Outer is ST 278. The differential shaft (upper shaft) bearing is ST 239. These are SUPER A numbers, I imagine the A numbers are the same, double check first. If you do not have a parts book, you need to look at the diagrams on A CIH dealers computer to make sure you get the right bearing.
