Low OIl Pressure. Am I doing damage??
AC Hodges
10-16-2005 12:09:47
Have a Super C that I've been working on and decided to see what the oil pressure was really doing. Put a test guage in and got results that seemed low. At working temp (160 to 180) it only shows 23 lbs at high idle and 8 lbs at idle.Has never made any noise, doesn't smoke and seems like a strong engine. Should I leave well enough alone or consider this a problem?
AC Hodges
10-16-2005 19:31:08
 Re: Low OIl Pressure. Am I doing damage?? in reply to AC Hodges, 10-16-2005 12:09:47
Thanks for the peace of mind. Think I'll wait for another reason to take the pan off. Going into the brakes next.
El Toro
10-16-2005 16:32:51
Go to page number 9 on this forum and look at scott2's posting on a SuperA and read slappy's
posting on how he raised the oil pressure on his tractor. Hal
Haas
10-16-2005 16:00:22
With the oil pressure you have, you are not doing any damage. It will run for a long time that way.
Hugh MacKay
10-16-2005 13:30:32
AC Hodges: I've seen these little engines go a long time at similar oil presure. As Andrew said you can probably improve it some buy fixing warped plate on end of pump or gasket.
My 130 has been running a lot of years just that way and has seen a lot of hard work. I'm waiting for another good reason to take the oil pan off, like a leak, but it just never happens.
Andrew Z
10-16-2005 12:40:44
What kind of oil are you running sometimes that can lead to low pressure. Also the oil pump bottom plate could be warped. or bad gasket. I would say that 23lbs aint that bad, Seen the Ford N series run in the 10lbs range when hot the guy who owend it says that the nature of them. Andrew
