Farmall 100 Hydraulic
Beamer
10-16-2005 16:44:11
I have a 1954 100 with hydraulic fluid getting into the crankcase. I know the cause if a bad seal in the hydraulic pump. I replaced the seal on the original pump because of this same problem and it fixed the leaking. Because of other problems I had to replace the pump 5 months ago with a new one. Now it leaks. I am using Universal Trans/Hydraulic Fluid. Should I be using another type fluid?
scotty
10-17-2005 04:34:28
 Re: Farmall 100 Hydraulic in reply to Beamer, 10-16-2005 16:44:11
Beamer, Your using the right fluid, my guess would be the o-ring in the new pump is shot. Which seems strange, but your going to have to take it apart, and inspect the seal and while your at it check the pump shaft also.
scotty
