856 Gas Tank
Hoofer
10-16-2005 16:55:25
Gas tank has lots of fine rust/sludge in it. Had tank of last winter and flushed. Any way besides new tank for peremanent fix?
olen
10-16-2005 17:57:09
 Re: 856 Gas Tank in reply to Hoofer, 10-16-2005 16:55:25
hoofer look up a product called evapo-rust.com and this product will remove all the rust,did it to my farmall c's tank. very easy product to use with no danger whatsoever,good luck
Hoofer
10-16-2005 20:08:37
 Re: 856 Gas Tank in reply to olen, 10-16-2005 17:57:09
Thanks for the reply. One question, How does envapo-rust work? Must I drain the tank or just add it to gas??
olen
10-17-2005 20:12:52
 Re: 856 Gas Tank in reply to Hoofer, 10-16-2005 20:08:37
the product can be added to the tank after you have drained the gas,to do it right you will need to pull the tank where you can turn the tank and clean the whole inside,it is a water based product so there is no problem with an kind of corrosive type material.if you need any kind of tech support they will be glad to inform you,thanks for the intrest.
