TA/Rear End Noise
iester
10-16-2005 18:19:59
I have a 350 utility tractor,ipto/ta/ps/gas.I done a double split,rebuilt engine and replaced TA seals.On second split(between end of TA and rear end} I noticed the gear on the end of TA was rough. So then I looked at the gear in the rear end that the TA gear connects to and it was missing a tooth. I though this would be okay.Every thing works but i'm getting a clanging/knock noise from that area.If engine clutch is deppresed no noise,So would broke tooth cause this noise? I know I will have to split again to replace gear,Will I have to remove top off rear end to replace? Any help? Thanks
captaink
10-17-2005 08:59:37
 Re: TA/Rear End Noise in reply to iester, 10-16-2005 18:19:59
The broken tooth may well be causing the noise as this gear (the back one on the TA) drives the lower (countershaft) in the transmission anytime the clutch is engaged. I’m almost positive that you will need to take the cover off, to get the gear out of the housing. Maybe someone else knows a trick I"m not aware of.
