806 engine noise
bgud
10-16-2005 18:25:09
Hi I'm working on my neighbors 806 diesel and its got a knock or rattle in the engine. I pulled the oil pan off and there were small pieces of metal in the pan that looked like parts of teeth from a gear. I can see the crank and idler gears and they look ok. I am wondering if there is something common that fails in these engines. Thank You
IHC Guy
10-17-2005 09:44:19
 Re: 806 engine noise in reply to bgud, 10-16-2005 18:25:09
I would be on the safe side and overhaul it. If your havin problems now and all you do is correct that specific problem, another one could be lurking around the next corner.
El Toro
10-17-2005 07:21:14
I think you need to investigate further to see where those teeth came from. If you saved the oil from the crankcase a lab could determine how much metal shavings are in that oil. That engine probably needs to be torn down and completely degreased and cleaned of any metal. It probably has circulated throughout the engine.
Hal
Nat
10-17-2005 06:18:14
These engines are pretty much rock solid and bulletproof, so you just have a random failure there.
Metal in the oil pan is BAD.
bgud
10-17-2005 08:29:19
 Re: 806 engine noise in reply to Nat, 10-17-2005 06:18:14
Hi thanks for the info guys I think I'll have to start into it further. I did send in a oil sample and the main thing they found was copper they say is from the mains.
El Toro
10-17-2005 11:14:01
 Re: 806 engine noise in reply to bgud, 10-17-2005 08:29:19
That doesn't sound too good, hope the crankshaft is ok. Hal
