Tire Chains
PAULIH300
10-16-2005 18:48:33
Has anyone had any experience with tire chains of the style where 2 cross chains are linked together (sort of in a "II" pattern)? The added steel across the treads of ag type tires should give added traction on ice and snow.On a 300U every little bit can only help....
MN Scott
10-16-2005 20:45:22
 Re: Tire Chains in reply to PAULIH300, 10-16-2005 18:48:33
I've posted a link below from a company that has high quaility chains at a fair price. I assume you are talking about the duogrip chains at the top of the page. I run these and they work very good under all conditions. Very good to prevent side slip but are a little rough on paved roads. I also run a pair of the double ring chains at the bottom of the page. They are also good in all condition's especially icy conditions but do tend to slip sideways easier. The ladder type chains are totally worthless on farm tractors so don't waste your money on them!
JB2
10-16-2005 20:05:41
Hi Paul,
See link below for chains my brother uses on his 495 with loader. They do a great job but would not recommend for paved or interlock driveway.
Link
JB2
TFR Jim
10-16-2005 19:50:25
Kind of! I had a 2N Ford and tire chains for it, then I put on new tires with a greater angle on the lugs and the original chains fell between the lugs. So, I welded two chains between two of the cross chains already there. It worked. Then, I sold the 2N, and I have just enlarged these same chains for my 300U. Mine has the long bar/short bar tread and I fear regular tire chains would slip between the lugs on it also. Haven't tried the chains on the 300U yet.,
Hayfarmer
10-16-2005 19:47:56
On my JD430U I have the kind that just goes across the tire, like a car or truck chain. They are gook on the highway but lack something on ice or show in that they tend to pull in around the lugs. I think the best chains are the ones with a big O ring between the bars. The ones you mention should be ok though.
