Filter for the hydrolic pump on a 350 U
Don Wells
10-17-2005 09:07:04
Can't seem to get any fluid to the pump is there a filter, if so where?
Thanks
Don
Don Wells
10-17-2005 16:43:45
 Re: Filter for the hydrolic pump on a 350 U in reply to Don Wells, 10-17-2005 09:07:04
the only way I can see is to take the whole top off, the way it looks I will need to take both remote valves off am I right?:
iester
10-17-2005 18:18:40
 Re: Filter for the hydrolic pump on a 350 U in reply to Don Wells, 10-17-2005 16:43:45
I left the valves on,used a {come a long) but attach chain shorter on valve side as it is heaver.Lift straight up as to not damage screen.Screen is about $65.00 to $85.00 from case ih.Mine had about inch & half of sandy sludge in resivore
PAULIH300
10-17-2005 09:33:40
The screen is under the seat.The cast metal top removes(heavy) and the screen is under it.
