Need bearing number for differental shaft.
Tiny TIm
10-17-2005 16:58:50
I hoping to try to get the number for the bearing for the differental drive shaft on the right side of my "A: Farmall. It is the one with the snap rings on the top part of the housing. The gears on it turn the bull gear on the bottom rear axle. Any help would be thankful--hoping to come out cheap--if there is such a thing..... ..... ....Tim
El Toro
10-18-2005 07:22:00
 Re: Need bearing number for differental shaft. in reply to Tiny TIm, 10-17-2005 16:58:50
Your local Case/IH dealer should have this info
on their computer, if not call 1-800-732-0017
and ask for farm equipment parts. You can email them too at bhershey@hoober.com. Hal
PS: You can have the old bearing cross-referenced
at most auto parts store if there's a number on the old bearing.
