Farmall H Throttle Butterfly Bushing Problem
John In Ct
10-17-2005 18:02:01
I posted about this #$%%^ bushing a few weeks ago, thanks to everyone that helped. My problem now is that I think the brass bushing is too long!!! I installed it ALL of the way in, reamed it to .2505" but can't get the throttle shaft in far enough to get the butterfly in correctly. The butterfly screw holes don't quite line up with the throttle shaft holes. Could it be the brass bushing is just too long. The Throttle shaft and brass bushing are new IH and the butterfly is NOS. Thanks!!
RustyFarmall
10-17-2005 21:30:29
 Re: Farmall H Throttle Butterfly Bushing Problem in reply to John In Ct, 10-17-2005 18:02:01
How clean is the hole on the other side?
John in Ct
10-18-2005 05:58:36
 Re: Farmall H Throttle Butterfly Bushing Problem in reply to RustyFarmall, 10-17-2005 21:30:29
Thanks for replying. The hole is clean, I wire brushed it (round wire brush). It did look like the end had a taper on it, it wasn't machined flat. The new bushing has a taper too so I put that end in first.
RustyFarmall
10-18-2005 08:10:31
 Re: Farmall H Throttle Butterfly Bushing Problem in reply to John in Ct, 10-18-2005 05:58:36
Let me think some more. I have a couple out in the shop that are already taken apart, I'll go look.
Janicholson
10-18-2005 11:44:07
 Re: Farmall H Throttle Butterfly Bushing Problem in reply to RustyFarmall, 10-18-2005 08:10:31
Look at the plate, if it is a complete circle, the bushing must be smoothed to match the contour of the bore. A dremmel grinder with a drum sander works well.
JimN
